Ir para o conteúdo principal
How to load HP Deskjet 6122 paper
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
  1. How to load HP Deskjet 6122 paper, How to load HP Deskjet 6122 paper: passo 1, imagem 1 %32
    • Open the paper tray to see if it is empty.
  2. How to load HP Deskjet 6122 paper: passo 2, imagem 1 %32
    • If the paper tray is empty, add paper to the tray.
    • If there is already paper in the tray, realign the paper so that it fits in the gears, and can feed through properly.
  3. How to load HP Deskjet 6122 paper: passo 3, imagem 1 %32
    • Ensure that all paper is in the correct tray.
    • The correct tray is on the upper deck of the printer.
  4. How to load HP Deskjet 6122 paper: passo 4, imagem 1 %32
    • Run the printer to verify it now prints.
    • If the paper still does not run through the printer, inspect the paper tray again.
  5. How to load HP Deskjet 6122 paper: passo 5, imagem 1 %32
    • Remove any paper that looks to be overloading the tray feeder.
    • Sometimes there can be too much paper in the tray, preventing it from working properly.
  6. How to load HP Deskjet 6122 paper: passo 6, imagem 1 %32
    • Try to print one last time. If it still fails, consider consulting a page to update drivers.
Conclusão
Joe
Membro desde: 10/14/11
1 Reputação
Autoria de 4 guias
Equipe
James Madison, Team 2-5, Allen Fall 2011 Membro de James Madison, Team 2-5, Allen Fall 2011
JMU-ALLEN-F11S2G5
1 Membro
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 863
