Introdução
Is your car not starting? Is there a clicking noise when you turn your key in the ignition? If yes, then you have a dead battery. Follow the directions below in order to jump start your car!
O que você precisa
Pop open the hood of the Insight by pulling the lever located here:
If your car still does not run after all of this, call a mechanic because you may have a bigger problem than a dead battery.
2 comentários
When I start the engine, the alarm is going on. How to turn it off?
