Introdução
If you purchased a Xbox Wireless Receiver for Windows and are wondering how to use it in Windows 7/8.x, this guide will show you how to install the drivers. Since Microsoft is pushing Windows 10 as hard as they need to (despite many users not wanting it or preferring to wait), problems like this will come up.
Since Microsoft wants to make this as hard as possible on Windows 7/8.x users, this guide will show you how to manually install the driver and get it working.
Guide notes
  • In most cases, the receiver will pick up the driver correctly. However, I have included manual installation instructions for situations where this does not happen.
  • Windows 10 users: Refer to the Windows 10 guide.
  1. Plug your Xbox Wireless Receiver into your PC and see if the driver gets picked up automatically. If it does not, you will need to install the driver manually. Plug your Xbox Wireless Receiver into your PC and see if the driver gets picked up automatically. If it does not, you will need to install the driver manually.
    • Plug your Xbox Wireless Receiver into your PC and see if the driver gets picked up automatically. If it does not, you will need to install the driver manually.
  2. Try this method first. Mircrosoft has pulled the driver from the public Update catalog. While this method isn't the most reliable, it is still worth trying as it works in most scenarios.
    • Try this method first. Mircrosoft has pulled the driver from the public Update catalog.
    • While this method isn't the most reliable, it is still worth trying as it works in most scenarios.
    • Before opening Device Manager, give Windows an opportunity to pick up the driver automatically. If it does not work, the driver will need to be installed manually.
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Open Device Manager. The best method to open Device Manager varies by OS. Windows 7: To open Device Manager in Windows 7: Open the start menu and right click Computer. Select Manange and locate Device Manager. Windows 8.x: Right click the Windows logo in the taskbar. Select Device Manager.
    • Open Device Manager. The best method to open Device Manager varies by OS.
    • Windows 7: To open Device Manager in Windows 7: Open the start menu and right click Computer. Select Manange and locate Device Manager.
    • Windows 8.x: Right click the Windows logo in the taskbar. Select Device Manager.
    • Double click XBOX ACC and verify your error code is Code 28. Click Update Driver and you will see a window with two options.
    • Before manually installing the driver, try selecting Search automatically for updated driver software. If this does not work, the driver will need to be installed manually.
  5. I do not have a Win7/8.1 x86 backup. Sorry :(. If the automatic installation does not work, download the driver from this driver backup from Microsoft Update Catalog. The unzipped and compressed .cab file can be used, but needs to be unzipped with 7Zip.
    • I do not have a Win7/8.1 x86 backup. Sorry :(.
    • If the automatic installation does not work, download the driver from this driver backup from Microsoft Update Catalog. The unzipped and compressed .cab file can be used, but needs to be unzipped with 7Zip.
    • Select Browse my computer for driver software.
    • Locate the folder where the driver is downloaded, and select Copy address as text. Paste this location into the box under Search for drivers in this lcoation:.
    • Click Next and install the driver.
  6. To verify the driver was installed correctly, check if the receiver shows up under Network Adapters. If the driver was installed correctly, this is where the receiver will be found.
    • To verify the driver was installed correctly, check if the receiver shows up under Network Adapters. If the driver was installed correctly, this is where the receiver will be found.
Conclusão
2 outras pessoas concluíram este guia.
Nick
46.401 reputação
38 Guides authored
Equipe
Master Techs Membro de Master Techs
Community
285 Membros
800 Guides authored
I assume this does not work with the new version of the dongle
Jason Douglas - Responder
The small one only works in Windows 10. The fat one works in 7/8.x and 10. There is a dedicated W10 guide with a warning related to drivers.
Nick -
Thank you. It's a shame. Such intentional and shady practices from Microsoft, blockade on a driver. You seem to really know your stuff… do you know if the Windows 10 dongle has features the old one does not? Since I don't even need to google it to know the old dongle is no longer for sale outside of second-hand.
Not that I'm aware of.
I can still find the old one new so it's available. I doubt it's discontinued.
Nick -
I know this post is old… but I found it to be of the only help so far…
I got hung up on Step 4. Can you please explain in detail how to “Locate the folder where the driver is downloaded, and select Copy address as text. Paste this location into the box under Search for drivers in this location: “ ? I have literally tried everything and couldn’t get to that point. I am still getting Windows was unable to install your XBOX ACC Windows could not find driver software for your device. If you know the manufacturer…blah blah blah etc etc.
Larry G - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 52
Últimos 7 dias: 370
Últimos 30 dias: 1,647
Todo: 14,176
