Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Follow the steps in this guide to Force Restart an iPhone 7.
  1. To force restart your device, press and hold both the Sleep/Wake and Volume Down buttons for at least ten seconds. This Force Restart procedure is different from previous model years since the iPhone 7 series does not have a physical Home Button to press down.
    • To force restart your device, press and hold both the Sleep/Wake and Volume Down buttons for at least ten seconds.
    • This Force Restart procedure is different from previous model years since the iPhone 7 series does not have a physical Home Button to press down.
  2. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Confira os kits
    Enough RAM
    For All The Tabs
    Confira os kits
  3. Continue holding both buttons for about 10 seconds, until the Apple logo appears.
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
  4. Once the Apple logo appears, release both buttons and your iPhone will restart.
    • Once the Apple logo appears, release both buttons and your iPhone will restart.
Conclusão
You have successfully restarted your iPhone 7.
73 outras pessoas concluíram este guia.
Chris Mason
Membro desde: 31/01/2016
4.632 Reputação
2 Guias de autoria
Equipe
Fixteq Membro de Fixteq
Business
1 Membro
14 Guias de autoria
Thanks a million, I couldn't figure out why the old technique didn't work.
sinwillett - Responder
It's my pleasure Sinwillett
Chris Mason -
You can learn something new everyday!
Andrew Bucknell - Responder
Happy to help, Andrew :)
Chris Mason -
Hello, I am an issue with my iPhone 7 . After submerged it in water for a few second . It’s started freezing and taking longer time to boot . Then the internal an external speaker stopped working . Please what do I do
Ovie Brume - Responder
thank you very much ! My iPhone 7 crashed and the ominous blues screen appeared… I couldn’t do anything, not even turn off the iPhone (pressing and holding the Sleep/Wake button didn’t work; I tried doing the same with Sleep/Wake and Home button simultaneously, it didn’t work either). I was already going to do the reset of the iPhone connecting it to iTunes, then I found your website while looking for “how to change iPhone battery by yourself” instructions … Luckily it was not necessary !
Lorenzo - Responder
thank you very much ! My iPhone7 crashed, and the ominous “blue screen” appeared. I couldn’t do anything, not even turning off the mobile (pressing and holding the Sleep/Wake button didn’t work, nor doing the same with Sleep/Wake and Home button).
I was already going to reset the iPhone connecting it to iTunes, then I found your website (thinking of turning off the iPhone by removing the battery, I was looking for instructions on how to remove it). I could turn off the iPhone, the apple logo appeared and now everything is ok..
Thanks again !
Lorenzo - Responder
hello, i have an issue with my iphone 7. it has of use less than a year and one day it stop working. I Try everything to get it out of the locked screen but it's impossible, I don t know what else to do. I also try to force the restart but nothing, the screen is still balck
does anyone kow what else i can do
maria - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 54
Últimos 30 dias: 228
Duração total: 15,375
