Ir para o conteúdo principal
How to force restart the iPhone 7 Plus
  1. How to force restart the iPhone 7 Plus, How to force restart the iPhone 7 Plus: passo 1, imagem 1 %32 How to force restart the iPhone 7 Plus, How to force restart the iPhone 7 Plus: passo 1, imagem 2 %32
    • To force restart your device, press and hold both the Sleep/Wake and Volume Down buttons for at least ten seconds.
    • This Force Restart procedure is different from previous model years since the iPhone 7 series does not have a physical Home Button (rather, it has a haptic button) to press down.
    My iPhone 7 Plus has a physical Home Button.
    Tony Olson - Responder
  2. How to force restart the iPhone 7 Plus: passo 2, imagem 1 %32
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
    What of if it didn't work after all the process
    Oma Livinus - Responder
    I boosted the battery and put it back it started to hot, the whole problem started after the battery drained off overnight
    Please what do I need to do to have the phone working again?
  3. How to force restart the iPhone 7 Plus: passo 3, imagem 1 %32
    • Once the Apple logo appears, release both buttons and your iPhone will restart.
Conclusão
You have successfully restarted your iPhone 7 Plus.
87 outras pessoas executaram este guia.
Chris Mason
Membro desde: 01/31/16
4.881 Reputação
Autoria de 2 guias
Equipe
Fixteq Membro de Fixteq
Business
1 Membro
Autoria de 16 guias
15 comentários
This threw me off when my wife's iPhone 7 froze. Plain and simple write up!
Morgan Cordry - Responder
Glad to have helped :)
Chris Mason -
not work my phone disable
mufi suma - Responder
and I can't restore it
Still doesn’t work
Saleka Chang - Responder
This operation is limited to the screen showing a black screen or crash. If your device does not power on or power up, connect your device to a power source and charge it for up to an hour. If the battery mark still does not appear on the screen, check if the charging device is in good condition.
If you still can not boot you can contact Apple Support, confirm the problem before the official repair or repair by yourself.
Ou Hiroshizon -
hi
i have iphone 7 and its restart self again and again after apple logo ?
Ali Zain - Responder
it still dose now work it turns on the apple logo and turns right back off help me pleaseee
kayla carter - Responder
excellent, i really thought my phone died for a sec…I was planning on buying another one til i saw this..! I havent ever really needed to do this! thanks!
alenakwong - Responder
if it not work, maybe your ios device system has some problem, you need to use professional third-party software named Fucosoft iOS System Recovery which can solve any ios system problem.
You can get it from here:https://www.fucosoft.com/ios-system-reco...
david_flynn - Responder
I replaced daughters screen and digitizer on iphone 7 plus as her was smashed beyond repair and followed step by step..to my amazement all was working again but when trying to snap screen back on the phone has completely gone of…CAN SOMEBODY PLEASE HELP
Jane Foster - Responder
After the iphone logo appear it still not turning own, can someone advice what i should do next
Synica D'souza - Responder
Not work and that not my mine email need remove everything
Jenny Hamilton - Responder
Wow this needs to be deleted as the 7 + still has a home button!!!! This why u can’t allow ppl who don’t know what they’re talking about on the internet at all!
krlink01 - Responder
iPhone 7s unlock karna chahta hu aapne i d vul gyahu na
Pradeep Sharma - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 23
Últimos 7 dias: 135
Últimos 30 dias: 660
Duração total: 251,726
