Introdução
Follow the steps in this guide to Force Restart an iPhone 7 Plus.
To force restart your device, press and hold both the Sleep/Wake and Volume Down buttons for at least ten seconds.
Continue holding both buttons for about 10 seconds, until the Apple logo appears.
What of if it didn't work after all the process
I boosted the battery and put it back it started to hot, the whole problem started after the battery drained off overnight
Please what do I need to do to have the phone working again?
Once the Apple logo appears, release both buttons and your iPhone will restart.
You have successfully restarted your iPhone 7 Plus.
87 outras pessoas executaram este guia.
15 comentários
This threw me off when my wife's iPhone 7 froze. Plain and simple write up!
Glad to have helped :)
Still doesn’t work
This operation is limited to the screen showing a black screen or crash. If your device does not power on or power up, connect your device to a power source and charge it for up to an hour. If the battery mark still does not appear on the screen, check if the charging device is in good condition.
If you still can not boot you can contact Apple Support, confirm the problem before the official repair or repair by yourself.
it still dose now work it turns on the apple logo and turns right back off help me pleaseee
excellent, i really thought my phone died for a sec…I was planning on buying another one til i saw this..! I havent ever really needed to do this! thanks!
if it not work, maybe your ios device system has some problem, you need to use professional third-party software named Fucosoft iOS System Recovery which can solve any ios system problem.
You can get it from here:https://www.fucosoft.com/ios-system-reco...
I replaced daughters screen and digitizer on iphone 7 plus as her was smashed beyond repair and followed step by step..to my amazement all was working again but when trying to snap screen back on the phone has completely gone of…CAN SOMEBODY PLEASE HELP
After the iphone logo appear it still not turning own, can someone advice what i should do next
Not work and that not my mine email need remove everything
iPhone 7s unlock karna chahta hu aapne i d vul gyahu na
My iPhone 7 Plus has a physical Home Button.
Tony Olson - Responder
