Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
appuyez brièvement sur le bouton d’augmentation du volume (1)
Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
37 outras pessoas executaram este guia.
9 comentários
helpfully, thanks!
All that happens for me is getting the slide to power off..never a reset. About to throw the phone.
Same as above. Slide to power off and not able to slide. It is frustrating.
I suggest you learn to read. hold power until apple sign appears. you need to keep holding it. not sliding it to switch off.
