Ir para o conteúdo principal
How to fix the main motor of Petcube Bites 2 Lite
O que você precisa
Vídeo de Apresentação
  1. How to fix the main motor of Petcube Bites 2 Lite, Prepare for disassembly: passo 1, imagem 1 %32 How to fix the main motor of Petcube Bites 2 Lite, Prepare for disassembly: passo 1, imagem 2 %32 How to fix the main motor of Petcube Bites 2 Lite, Prepare for disassembly: passo 1, imagem 3 %32
    • Start by pressing the 2 clips on each side of the device to remove the tread holder head.
    • Once inside, pry out the size insert and the treat motor cap.
  2. How to fix the main motor of Petcube Bites 2 Lite, Remove the treat holder: passo 2, imagem 1 %32 How to fix the main motor of Petcube Bites 2 Lite, Remove the treat holder: passo 2, imagem 2 %32
    • Unscrew the 2 larger Philips screws to be able to remove the base of the treat holder from the device body.
  3. How to fix the main motor of Petcube Bites 2 Lite, Get inside the device body: passo 3, imagem 1 %32 How to fix the main motor of Petcube Bites 2 Lite, Get inside the device body: passo 3, imagem 2 %32 How to fix the main motor of Petcube Bites 2 Lite, Get inside the device body: passo 3, imagem 3 %32
    • The core device can actually be accessed by the bottom; screws are hidden under the rubber pad.
    • The rubber pad is simply glued to the bottom, you can easily unstick it from the shell to gain access to the screws.
    • Be careful to only pull the rubber part and not the entire bottom. I initially tried to force it out and figured out the screw location by breaking it... don't do that.
    • Under the rubber pads are 4 Philips screws to get inside.
  4. How to fix the main motor of Petcube Bites 2 Lite, Remove the physical controls: passo 4, imagem 1 %32 How to fix the main motor of Petcube Bites 2 Lite, Remove the physical controls: passo 4, imagem 2 %32
    • Once inside, you'll find a board that hosts the physical controls of the device.
    • Remove the 2 Philips screw to remove it from its place.
    • Then disconnect the ribbon cable and put the board away.
  5. How to fix the main motor of Petcube Bites 2 Lite, Open the device core: passo 5, imagem 1 %32 How to fix the main motor of Petcube Bites 2 Lite, Open the device core: passo 5, imagem 2 %32 How to fix the main motor of Petcube Bites 2 Lite, Open the device core: passo 5, imagem 3 %32
    • Once the controls are removed, you can simply slide the core of the device out of its shell.
    • You'll find 3 Philips screws (2 on the left, 1 on the right) to get inside the core.
  6. How to fix the main motor of Petcube Bites 2 Lite, Remove the motor: passo 6, imagem 1 %32 How to fix the main motor of Petcube Bites 2 Lite, Remove the motor: passo 6, imagem 2 %32 How to fix the main motor of Petcube Bites 2 Lite, Remove the motor: passo 6, imagem 3 %32
    • The 3 Philips screws holding the motor to the structure can be removed.
    • The motor won't slide out immediately – you'll also need to remove the encoder sensor. Just pull it out carefully from its socket.
    • While trying to slide the motor out, make sure to disconnect its cable from the main board.
    • The motor can then be disassembled by removing the 2 Philips screw holding its shell.
  7. How to fix the main motor of Petcube Bites 2 Lite, Fix the motor: passo 7, imagem 1 %32 How to fix the main motor of Petcube Bites 2 Lite, Fix the motor: passo 7, imagem 2 %32
    • Inside the motor, just realign all the cogs together so that everything spins together.
    • If you want to test out the motor before reassembling everything:
    • Reconnect all the cables that were disconnected during disassembly
    • Plug the device back in
    • Connect to the device through the Petcube app, and try flinging a treat
    • The motor will instantly respond (or not) and make it easier to find what's wrong, or if the motor needs replacement.
Conclusão
Then to reassemble the device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Émile Bélair
Membro desde: 06/08/23
187 Reputação
Autoria de 1 guia
3 comentários
Hello! This is very helpful.. mine doesn’t start up at all do you have any ideas on how to get the motor to start
Elizabeth Knowlton - Responder
This guide was super useful! Unfortunately, I found that the problem is that one of the gears broke off. Does anyone have any instructions on how to dismantle this type of motor in order to substitute the damaged gears? Thank you in advance!
Geraldine - Responder
Same here. 8 tooth gear snapped in half. Is there a part number for it?
Clint - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 30
Duração total: 511
