Ir para o conteúdo principal
How to fix huion pen 420 Dropped-drawing while hovering
O que você precisa
  1. How to fix huion pen 420 Dropped-drawing while hovering, disassemble: passo 1, imagem 1 %32 How to fix huion pen 420 Dropped-drawing while hovering, disassemble: passo 1, imagem 2 %32 How to fix huion pen 420 Dropped-drawing while hovering, disassemble: passo 1, imagem 3 %32
    • Remove the buttons first. (use a flat screw driver or something similar) (pic 1)
    • Push the silver tab & black tab down and push upwards to remove the mainboard
    • twist the white cylinder to adjust the height offset of the nub
    • if you want to fully dissasemble desolder the two copper leads and fully unscrew the while cylinder
    What so you mean black point!? I don't have it!!… I am using hs64 is that the problem?
    luna times - Responder
    The black point ( picture 2) is the round dot that looks like a button. It's just a lock, push it to open/remove the inside of the pen (pic 3). Try and find some way to open the inside of the pen if you don't see a button like that.
    thlong123 -
  2. How to fix huion pen 420 Dropped-drawing while hovering: passo 2, imagem 1 %32 How to fix huion pen 420 Dropped-drawing while hovering: passo 2, imagem 2 %32 How to fix huion pen 420 Dropped-drawing while hovering: passo 2, imagem 3 %32
    • Use a soldering iron to remove the wire (remember which one goes where.) (pic 1)
    • Mark the white plastic and the black one (so you know when to stop when screw it back) (pic 2)
    • Unscrew the white part. Just one or two turns to bring it back to the original position. If you would like to see what's inside, remember which way the spring goes when unscrew the whole thing. It's revrsed in this pic (pic 3)
  3. How to fix huion pen 420 Dropped-drawing while hovering, Reassemble: passo 3, imagem 1 %32 How to fix huion pen 420 Dropped-drawing while hovering, Reassemble: passo 3, imagem 2 %32
    • Put everything back together. Stop the white plastic at the mark. Put the tip on to see if the spring works (the tip moves freely; turn the white plastic back or forth to get a design pressure sensitivity).
    • Remember to pull the metal up or else the pen won't have power. (pic 2)
Conclusão
7 outras pessoas executaram este guia.
thlong123
Membro desde: 03/18/18
285 Reputação
Autoria de 1 guia
17 comentários
Man can I ask you something on google hangouts ? I couldn’t understand some points.
Peace Maker - Responder
I don't have hangout. Just ask here, I'll try to answer asap
thlong123 -
Why we need soldering iron?
Peace Maker -
To use in step 2
thlong123 -
I suspect this happened to mine but i dont have a soldering iron
Pixeled Forlife - Responder
If the tip drops on the floor, the white part will be easily pushed in, which tighten the tip and makes it thinks that you're writing. You need to loosen the white part by any mean. I would recommend buying a soldering iron (online usually cheaper). If you need the pen asap, buy a basic soldering iron at Walmart or home depot (find the cheapest one available) will , you don't need anything else.
thlong123 -
Any need to remove black plastic which is under the white one?
(sorry, I thought I answered this one already) In case you still want to know, you should not remove that black plastic.
thlong123 -
Thank you so much, this saved me dollars from buying new pen. What bonus, I really had some fun :3
danghung171095 - Responder
Hi i something to know
ZELDER/ زيلدر - Responder
You did nothing just take things off and bring it back
i dont think it is necessary to desolder the copper coil, the white bit just needs to be screwed in or out to get the end result. I think there’s enough slack in the copper for most people that they don’t need to desolder
Goopes H - Responder
Hey , do we really need to solder it? And does this method really work? I am asking this because the pen online is expensive than the whole tablet and the pen included
sarojmishra1972 - Responder
How to remove the power button and spring please help asap
Simanta - Responder
help,, the copper wire broke when i tried to pull it :’))
guh - KFBeats - Responder
Hi! I have the same problem with the Huion PW100 pen but it looks like different from the pen of your guide. Can you help me? Please...
Gabriele Matuka - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 63
Duração total: 17,690
