Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
While looking for repairs for the home button, I stumbled upon stupid ideas of spraying WD40 or white spirit onto the button, without disassembling the device. Because of the design of the button, white spirit (or worse, WD40) can NEVER reach the contacts
Iphone's home button tends to become unresponsive over the time. These couple of pictures show the reasons and easy fix. Photos are taken during the repair of my own device. Probably it works with other iphones too.
O que você precisa
Use the edge of an iPod opening tool or your fingernail to lift the home button ribbon cable retainer.
You need really thin blade to carefully peel off the plastic film from the back of the button. Do NOT touch the glue with your finger!
On reassembly, you have to position the steel cap in the center of copper contact ring, placing plastic sticker into its respective cavity on the back of the button.
Press the sticker firmly into its place. Don't worry if it doesnt stick all the way round. its position under the glass keeps the details in place. Again, try to prevent touching the glue while disassembling.
Congrats! Re-assemble your device and enjoy your revived home button!
37 outras pessoas executaram este guia.
