Ir para o conteúdo principal
How to fix a torn piece of fabric
O que você precisa
  1. How to fix a torn piece of fabric, Torn Fabrics: passo 1, imagem 1 %32
    • The tools needed are in the following pictures. Make sure the fabric you are using matches the fabric being repaired if its clothing.
  2. How to fix a torn piece of fabric: passo 2, imagem 1 %32
    • Press the thread through the hole of the needle. Getting the end of the needle wet will help it through easier. Once that is done make a firm knot to hold it in place.
  3. How to fix a torn piece of fabric: passo 3, imagem 1 %32
    • Place the new fabric on top of the torn fabric and poke the needle through the end of the tear. Make sure to make a knot to hold the first incision through.
  4. How to fix a torn piece of fabric: passo 4, imagem 1 %32
    • Began looping your thread through the new fabric on top of the torn fabric.
  5. How to fix a torn piece of fabric: passo 5, imagem 1 %32
    • Take your time looping the thread through and make sure it is secured.
  6. How to fix a torn piece of fabric: passo 6, imagem 1 %32
    • Once at the end of the fabric make a secured knot and cut any extra fabric left.
  7. How to fix a torn piece of fabric: passo 7, imagem 1 %32
    • Look at your finished project to make sure it is clean.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 27
Duração total: 526
