Ir para o conteúdo principal
How to fix a stuck Sony Cyber-shot DSC-P10 lens cover
O que você precisa
  1. How to fix a stuck Sony Cyber-shot DSC-P10 lens cover, How to fix a stuck Sony Cyber-shot DSC-P10 lens cover: passo 1, imagem 1 %32
    • Pull back the lens shutters manually if necessary.
    • NOTE: A can of compressed air can be found in almost any store
  2. How to fix a stuck Sony Cyber-shot DSC-P10 lens cover: passo 2, imagem 1 %32 How to fix a stuck Sony Cyber-shot DSC-P10 lens cover: passo 2, imagem 2 %32
    • Blow the area inside the flaps and around them with the can of compressed air.
    • If the flaps don't immediately work, continue to attempt to blow the debris out while periodically checking to see if the problem is fixed
Conclusão
After following this guide, the lens flaps should open and close freely as necessary.
Uma outra pessoa concluiu este guia.
Renee
Membro desde: 10/29/11
125 Reputação
Autoria de 1 guia
Equipe
UW Stout, Team 1-1, Zhou Fall 2011 Membro de UW Stout, Team 1-1, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G1
Membros da 5
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 53
Duração total: 4,876
