Ir para o conteúdo principal
How to fix a ripped back pocket of jeans
O que você precisa
  1. How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: passo 1, imagem 1 %32 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: passo 1, imagem 2 %32 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: passo 1, imagem 3 %32
    • Pin down the ripped portion of the jeans back pocket.
    • Use as many pins as needed to ensure the pocket does not slip from the correct place while sewing.
  2. How to fix a ripped back pocket of jeans: passo 2, imagem 1 %32 How to fix a ripped back pocket of jeans: passo 2, imagem 2 %32
    • Thread the needle with the polyester thread.
    • Use about an arms length of thread to ensure that you have enough to sew with.
  3. How to fix a ripped back pocket of jeans: passo 3, imagem 1 %32
    • Cut the ends of the thread.
  4. How to fix a ripped back pocket of jeans: passo 4, imagem 1 %32 How to fix a ripped back pocket of jeans: passo 4, imagem 2 %32
    • Tie a double knot at the end of the two threads.
  5. How to fix a ripped back pocket of jeans: passo 5, imagem 1 %32 How to fix a ripped back pocket of jeans: passo 5, imagem 2 %32
    • Start to sew from the bottom of the pocket up.
  6. How to fix a ripped back pocket of jeans: passo 6, imagem 1 %32 How to fix a ripped back pocket of jeans: passo 6, imagem 2 %32
    • Remove pins as the needle and thread approaches the pins.
  7. How to fix a ripped back pocket of jeans: passo 7, imagem 1 %32 How to fix a ripped back pocket of jeans: passo 7, imagem 2 %32 How to fix a ripped back pocket of jeans: passo 7, imagem 3 %32
    • Loop the needle through the thread to tie a knot to end and secure the sewing.
  8. How to fix a ripped back pocket of jeans: passo 8, imagem 1 %32
    • Cut the loose threads to clean up the sewing.
Conclusão
Ashley Dembroski
Membro desde: 07/19/20
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 73
Duração total: 3,371
