Ir para o conteúdo principal
How to fix a rattling window, E46 M3
O que você precisa
Vídeo de Apresentação
  1. How to fix a rattling window, E46 M3, Identify the screws: passo 1, imagem 1 %32
    • The door card is held securely in place with 5 screws.
    • Keep in mind the door card has up to 3 wire bundles attached to it. Be careful when removing it! Be prepared to support it while dealing with the wires.
  2. How to fix a rattling window, E46 M3, Remove screw covers: passo 2, imagem 1 %32 How to fix a rattling window, E46 M3, Remove screw covers: passo 2, imagem 2 %32
    • Using a spudger, work off the cap of the first screw. The cap is tight; you may need a jimmy or metal spudger.
    • Using the flat end of a spudger, remove the airbag emblem. The emblem has clips on the top and bottom -- work carefully.
  3. How to fix a rattling window, E46 M3, Remove bolts: passo 3, imagem 1 %32
    • Using a T20 Torx driver with extension, remove all 5 bolts.
  4. How to fix a rattling window, E46 M3, Remove mirror control: passo 4, imagem 1 %32
    • If you're working on the driver side door, remove the mirror control module. Disconnect it from its wiring plug.
  5. How to fix a rattling window, E46 M3, Pop door card clips: passo 5, imagem 1 %32 How to fix a rattling window, E46 M3, Pop door card clips: passo 5, imagem 2 %32
    • Using a trim tool or similar, begin at the bottom of the door card and pop the card away from the door frame.
    • After you've released the bottom clips, work your way around.
    • You will need to lift the door card from the door frame in order to fully release it. Be careful!
    • Disconnect the following from the door panel:
    • Unlocking cable
    • Speaker cable(s)
    • Set the door panel aside.
  6. How to fix a rattling window, E46 M3, Door panel removed!: passo 7, imagem 1 %32
    • The door panel is now removed.
    • You will see the airbag module, vapor barrier, and other components.
  7. How to fix a rattling window, E46 M3, Inspect the post: passo 8, imagem 1 %32 How to fix a rattling window, E46 M3, Inspect the post: passo 8, imagem 2 %32
    • Very gently, peel back the vapor barrier to expose the retaining bolt.
    • Roll the window up.
    • The tar-like substance used to seal the vapor barrier to the door frame WILL release itself to a gentle pull, but it is EXTREMELY sticky, and too much pulling will tear your barrier. Slow and steady is the name of the game!
    • Inspect the bolt. It is probably missing a nut!
  8. How to fix a rattling window, E46 M3, Inspect the other bolt: passo 9, imagem 1 %32
    • While you're in here, inspect and tighten the bottom bolt.
  9. How to fix a rattling window, E46 M3, Find and replace!: passo 10, imagem 1 %32
    • Look in the bottom of your door and locate the nut that fell off that top bolt.
    • Replace the nut onto the upper bolt and tighten.
    • In a pinch, you can use a little bit of that tarry substance to temporarily paste the nut to your fingertip in order to screw it on to the bolt.
    • Ta da! Now closing the door sounds great!
Conclusão
To reassemble your door, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Dom Santangelo
Membro desde: 09/19/16
592 Reputação
Autoria de 3 guias
Um comentário
What is this bullshit? Ever think people may have both bolts there and tightened down still? Ever think other ifixit $@$* may still need to occur? And this is all you have to offer? Awesome thoroughness…
spamaccount420 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 43
Duração total: 8,766
