Ir para o conteúdo principal
How to fix a dead IHome iBT76
O que você precisa
  1. How to fix a dead IHome iBT76, How to fix a dead IHome iBT76: passo 1, imagem 1 %32 How to fix a dead IHome iBT76, How to fix a dead IHome iBT76: passo 1, imagem 2 %32 How to fix a dead IHome iBT76, How to fix a dead IHome iBT76: passo 1, imagem 3 %32
    • Flip the on/off switch to off.
    • Flip the speaker over on and remove the label.
    • Remove the four phillips head screws.
  2. How to fix a dead IHome iBT76: passo 2, imagem 1 %32
    • Remove the bottom plate.
    • Unplug the white plug.
    • Plug it back in.
  3. How to fix a dead IHome iBT76: passo 3, imagem 1 %32
    • Enjoy your speaker again.
Conclusão
8 outras pessoas executaram este guia.
Salemboot
Membro desde: 02/24/19
348 Reputação
Autoria de 1 guia
14Comentários do guia
OMG! Salemboot, you are absolutely incredible! First the lights went out, then it wouldn’t work without being plugged in, the charging light never came on, and it finally stopped working altogether…I was so disappointed. This was a gift with sentimental value so thank you very, very much!
aviteks - Responder
Double OMG !! Thanks for making us Dad’s look cool to our kids. Worked like a charm. I would not have had the courage to tackle this without your post. My little guy loves this speaker and uses it all the time. He was heart broken when it failed. Now he thinks I can fix anything. Many thanks!!
T Stu - Responder
How did you remove the bottom label?
Joel M -
How do I remove the label without breaking it??
Joel M - Responder
EXACTLY! How do you?
Hs Clan -
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 66
Ao todo: 5,027
