Pular para o conteúdo principal
Introdução
This is a simple repair. Open the device and reconnect the battery. No parts required, no screws. (for iPhone or Android)
FLIR will not repair FLIR ONE 2G! "if the device is under warranty, we replace the unit directly as they are not being repaired. ... The one and only option left for you, is to have it repaired somewhere else as we do not support units that are out of warranty."
Peças
Nenhum componente especificado.
  1. Open the device with the opening tool in crack along top edge of back side. Continue carefully opening the device around all four edges.
    • Open the device with the opening tool in crack along top edge of back side.
    • Continue carefully opening the device around all four edges.
  2. The two halves will separate very easily and the battery connector will detach very easily.
    • The two halves will separate very easily and the battery connector will detach very easily.
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. OPTIONAL
    • OPTIONAL
    • Lay two pieces of 30 gauge solid insulated wire (wire-wrap wire) onto connector. Press into the two slots to make connections.
    • CAUTION - any wire or probe larger than 30 gauge is likely to damage the connector.
    • Use a multimeter to check the battery voltage, it should be about 3.7 V.
  5. Carefully reconnect the battery. The two halves of the connector press together easily when properly aligned.
    • Carefully reconnect the battery. The two halves of the connector press together easily when properly aligned.
  6. Press the two halves of the case together. You might see the LED in the button light or start blinking!
    • Press the two halves of the case together. You might see the LED in the button light or start blinking!
  7. Charge the device. A blinking LED indicates charging, a steady LED indicates done.
    • Charge the device. A blinking LED indicates charging, a steady LED indicates done.
    • When charged, reconnect device to phone and try it!
    • You may get the message "Camera Files Not Received. Camera files could not be read, temperature accuracy and MSX alignment may be degraded." This is apparently a bug in some versions of the FLIR ONE App.
Linha de Chegada
8 outras pessoas concluíram este guia.
Frank Demarest
Membro desde: 17-10-2017
421 reputação
Autoria de 1 guia
Totally worked for mine! I almost gave up on it after seeing the YouTube video of the guy smashing his with a hammer. In addition I used a little bit of stablilant 22 contact enhancer product. Thanks Frank!
Todd - Responder
Cool you shared this info with other folks!
Worked for my Android device!
Dmitry G.L. - Responder
I can easily find a 185mAh battery but not a 350mAh. Not sure if anyone knows why its shrunk?
185 seems to work fine though.
Great guide. Sooooo easy.
georgedavies@hotmail.com - Responder
I have the Flir One Pro for Android with the same issue. I can’t figure out how to open it. I have an opening tool and there two plastic corners on the top connector face that come out. I can’t figure out how to get it open like you have.
chris - Responder
Nice guide. I accidentally broke the plastic connector on the mainboard (the pins are still soldered). Anybody know this connector type? Thx!
Peter D. - Responder
This is great ill try it but are there replacement batteries out there
Wesley Crutchfield - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 17
Últimos 7 dias: 114
Últimos 30 dias: 533
Todo: 6,463
