Ir para o conteúdo principal
How to fix a blown heater element in a Toaster
O que você precisa
Vídeo de Apresentação
    • Insert wisdom here.
    • how to fix a toaster
Conclusão
Not too difficult, you need patience though.
5 outras pessoas executaram este guia.
jon
Membro desde: 05/15/16
3.210 Reputação
Autoria de 22 guias
2Comentários do guia
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - Responder
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 84
Ao todo: 26,754
