Ir para o conteúdo principal
How to fix TC Electronic Level Pilot static noise
O que você precisa
  1. How to fix TC Electronic Level Pilot static noise, How to fix TC Electronic Level Pilot static noise: passo 1, imagem 1 %32
    • The bottom rubber base can be removed
  2. How to fix TC Electronic Level Pilot static noise: passo 2, imagem 1 %32
    • Spray the small opening there with some multi-purpose oil.
Conclusão
11 outras pessoas executaram este guia.
Alpha Dimension
Membro desde: 09/09/14
388 Reputação
Autoria de 1 guia
6 comentários
Not a good idea. Oil will &&^& it up dah.
stevenowlbassett - Responder
DeOxit (contact cleaner designed specifically for potentiometers) is what most people are recommending, not WD40 or dielectric grease..
Preferably DeOxit Gold, or at least not their (Hosa's) Fader Lube.
mystiphysician - Responder
Yes, use DeOxit or some similar contact cleaner
Eng Wei Chua - Responder
That knob became scratchy after some use. Cramolin contaclean helped, as always. Thanks for the teardown guide.
Daniel Leonov - Responder
Thanks Alpha Dimension for your disassembly guide.
If one needs to change it, it’s a Bourns potentiometer and its complete reference is PTD904-1020K-A103 (I’ve checked with measures on the potentiometer of my Level Pilot and with the PDF reference here : https://www.bourns.com/docs/product-data...)
Hervé HERRY - Responder
Yes oil is not a good idea. Thank you guys for the part. My one broke.
Alpha Dimension - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 24
Duração total: 5,654
