Ir para o conteúdo principal
How to fix Nikon D3000 shutter release button error
O que você precisa
  1. How to fix Nikon D3000 shutter release button error, How to fix Nikon D3000 shutter release button error: passo 1, imagem 1 %32 How to fix Nikon D3000 shutter release button error, How to fix Nikon D3000 shutter release button error: passo 1, imagem 2 %32
    • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
    • Remove three 3 mm x 5.5 mm from the bottom left of the camera bottom.
    • Lift the battery cover and remove two 3 mm x 5.5 mm screws from the bottom left of the camera.
    • Remove the screws from the bottom of the case to access the shutter gear.
  2. How to fix Nikon D3000 shutter release button error: passo 2, imagem 1 %32 How to fix Nikon D3000 shutter release button error: passo 2, imagem 2 %32
    • The second picture shows the bottom plate removed, but this is not necessary and requires intensive disassembling of the camera.
    • Blow out the red gear wheel to clean the wheel from any possible dust or debris.
    • Lubricate the red wheel to lessen the stiffness of the wheel's motion and rotate with the black plastic prying tool.
Conclusão
10 outras pessoas executaram este guia.
Josh
Membro desde: 08/26/15
307 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 14-7, Meier Fall 2015 Membro de USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
Membros da 4
Autoria de 6 guias
2 comentários
I have a d3200 that “at will” will throw this message, so incredibly random. It will be fine then …. the message. Always at the worst moment. I have checked the mirror path and that doesn’t seem to be catching at all. I think I want to try this fix you outlined, but I have. D3200 not a 3000… is everything the same?
MARY M DUNNIGAN - Responder
Hello there.
I attempt many times to resolve issue on my camera. I tried lubricate red gear wheel, but problem persisting.
Does any other thing I need to do?
Salvador Diaz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 21
Últimos 30 dias: 65
Duração total: 11,360
