Ir para o conteúdo principal
How to fix Mobee Magic Mouse disconnection issues
O que você precisa
Instruções em vídeo
Linha de Chegada
30 outras pessoas executaram este guia.
Peter Barnett
Membro desde: 09/04/16
732 Reputação
Autoria de 1 guia
Equipe
4 comentários
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - Responder
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - Responder
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - Responder
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 54
Últimos 30 dias: 188
Duração total: 36,341
