Ir para o conteúdo principal
How to fix Logitech Anywhere MX Phantom Double Click
O que você precisa
  1. How to fix Logitech Anywhere MX Phantom Double Click, Front Screw Removal: passo 1, imagem 1 %32
    • The front screws are underneath the front gliders. The can be removed with a butterknive or Plastic Opening Tool. The gliders have three layers, be careful not to seperate them.
  2. How to fix Logitech Anywhere MX Phantom Double Click, Removing Back Screws: passo 2, imagem 1 %32
    • The back screws are underneath the stickers with the battery images. You can either remove them, like I did, or just poke a hole into them to get to the screws.
  3. How to fix Logitech Anywhere MX Phantom Double Click, Identification of the Problem: passo 3, imagem 1 %32
    • After the four screws are removed, the top and the bottom part can be easily taken apart. In the top part the grove that was made by the click-sensor should be cleary visible. This causes the phantom double clicks.
  4. How to fix Logitech Anywhere MX Phantom Double Click, Solution of the Problem: passo 4, imagem 1 %32
    • Put a piece of tape over the groove.
Conclusão
63 outras pessoas executaram este guia.
43Comentários do guia
Worked well for me, lets see how long it'll last.
Wynadorn - Responder
Worked for me too...saved a great little mouse!
jcrhino - Responder
Thank you for this hint! It worked perfectly
Wojciech Gradkowski - Responder
Thank you, it worked!
Jakab Ponoczky - Responder
Thank you for this guide! Got my mouse working and saved me some money :)
Kon-Kon Chao - Responder
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 45
Últimos 30 dias: 299
Ao todo: 50,538
