Ir para o conteúdo principal
How to fix Leaks in Shower Tiles by Caulking
O que você precisa
  1. How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: passo 1, imagem 1 %32 How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: passo 1, imagem 2 %32 How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: passo 1, imagem 3 %32
    • Using a putty knife, remove the old caulk from the surface.
    • While using the scraper, hold the sharp end away from you.
  2. How to fix Leaks in Shower Tiles by Caulking: passo 2, imagem 1 %32 How to fix Leaks in Shower Tiles by Caulking: passo 2, imagem 2 %32 How to fix Leaks in Shower Tiles by Caulking: passo 2, imagem 3 %32
    • Using a damp cloth, wipe the surface to remove the scraped caulking.
    • Using another cloth, wipe the surface with disinfectant.
  3. How to fix Leaks in Shower Tiles by Caulking: passo 3, imagem 1 %32 How to fix Leaks in Shower Tiles by Caulking: passo 3, imagem 2 %32 How to fix Leaks in Shower Tiles by Caulking: passo 3, imagem 3 %32
    • Place the caulking tube in the caulking gun.
    • Place the back of the tube into the gun.
    • Push the front of the tube inside.
    • Twist the hook at the end of the caulking gun inwards to hold the caulking tube in place.
  4. How to fix Leaks in Shower Tiles by Caulking: passo 4, imagem 1 %32 How to fix Leaks in Shower Tiles by Caulking: passo 4, imagem 2 %32 How to fix Leaks in Shower Tiles by Caulking: passo 4, imagem 3 %32
    • Cut the tip of the caulking tube at an angle.
    • Test the caulk on a paper towel before applying it on the surface.
    • Press the trigger on the caulking gun to release the caulk from the tube.
  5. How to fix Leaks in Shower Tiles by Caulking: passo 5, imagem 1 %32 How to fix Leaks in Shower Tiles by Caulking: passo 5, imagem 2 %32 How to fix Leaks in Shower Tiles by Caulking: passo 5, imagem 3 %32
    • Start caulking at the top of the surface and move down along the surface.
    • Place the tip of the caulking gun on the surface between two tiles and move it down at a steady pace.
    • Go back to the top and apply the caulking on the next tile, until all of the space between the tiles has caulking.
    • Hold the caulking gun with both hands to be steady.
  6. How to fix Leaks in Shower Tiles by Caulking: passo 6, imagem 1 %32 How to fix Leaks in Shower Tiles by Caulking: passo 6, imagem 2 %32 How to fix Leaks in Shower Tiles by Caulking: passo 6, imagem 3 %32
    • Using a damp finger, smoothen the caulking on the surface.
    • Keep a rag nearby to periodically wipe off any excess caulking.
    • Allow the caulking to dry for five minutes, before moving on to the next part.
  7. How to fix Leaks in Shower Tiles by Caulking: passo 7, imagem 1 %32 How to fix Leaks in Shower Tiles by Caulking: passo 7, imagem 2 %32 How to fix Leaks in Shower Tiles by Caulking: passo 7, imagem 3 %32
    • Now, apply the caulking in the horizontal direction.
    • Repeat the process in Step 5 and 6.
    • Allow the caulking to dry for 5 minutes before moving to the next part.
  8. How to fix Leaks in Shower Tiles by Caulking: passo 8, imagem 1 %32 How to fix Leaks in Shower Tiles by Caulking: passo 8, imagem 2 %32
    • Go over any areas that were missed or that don't have enough caulking.
    • Put a pea size amount of caulking in that area and smoothen it out with a damp finger.
  9. How to fix Leaks in Shower Tiles by Caulking: passo 9, imagem 1 %32 How to fix Leaks in Shower Tiles by Caulking: passo 9, imagem 2 %32 How to fix Leaks in Shower Tiles by Caulking: passo 9, imagem 3 %32
    • Let the surface dry for 20 minutes.
    • After the caulking has dried, remove the excess using a putty knife.
    • To avoid scratches while removing the excess, lay the scrapper flat towards the surface.
  10. How to fix Leaks in Shower Tiles by Caulking: passo 10, imagem 1 %32 How to fix Leaks in Shower Tiles by Caulking: passo 10, imagem 2 %32
    • In case there is still any excess, scrub over the scraped area with a damp cloth.
    • If there is any caulking left over, cover the tip of the caulking tube with a paper towel and store for later use.
    • The caulking tube can be left in the caulking gun or taken out by performing step 4 backward.
Conclusão
Clean the surface and completely let it dry before using it. It may take up to a full day to dry completely, so be prepared to not use the surface for a while!
Uma outra pessoa concluiu este guia.
Suman Grewal
Membro desde: 04/26/20
208 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 27
Ao todo: 1,817
