Pular para o conteúdo principal
Introdução
This guide will show how to fix squeaky parts on the wheelchair.
Ferramentas
Peças
Nenhum componente especificado.
  1. Locate the source of the squeaking. Typically, this will be one of the rear wheels, castor wheels, or brakes. Clean and remove any dirt or rust from the source of the squeaking.
    • Locate the source of the squeaking.
    • Typically, this will be one of the rear wheels, castor wheels, or brakes.
    • Clean and remove any dirt or rust from the source of the squeaking.
    • You may need to partially disassemble the squeaky part in order to thoroughly clean it.
  2. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Check for improper assembly.
    • Check for improper assembly.
    • Refer to the teardown to check that the wheelchair is properly assembled.
    • Check for proper lubrication. If not lubricated, lubricate thoroughly with bike grease.
  4. Roll the wheelchair around to check if the squeaking has stopped.
    • Roll the wheelchair around to check if the squeaking has stopped.
    • If the squeaking still continues, recheck the chair until the problem is fixed.
Conclusão
Squeaking can be caused by overly tightened connections. If problem still occurs after going through steps, try to slightly loosen bolts (half a turn of the wrench) near the source of squeaking.
Uma outra pessoa concluiu este guia.
Kali Slaughter
Membro desde: 19-04-2013
207 reputação
5 Guias de autoria
Equipe
Cal Poly, Team 14-8, Maness Spring 2013 Membro de Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Membros
7 Guias de autoria
A quick spray of Extralube C60 Trigger Spray will keep the components rust free and spinning for much longer... worth a go www.team-zx1.com
sandraphleb - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Todo: 1,876
