Introdução
Due to the many problems with cell phone signal and gps on LG G2, i will show you how to boost your gps and cell phone signal in 2 min.
Just watch the video below:
O que você precisa
Vídeo de Apresentação
Close the back panel.
I believe it did not work on my set, rather some of the clips on the back cover broke while taking it off
20 outras pessoas executaram este guia.
7 comentários
THANK YOU THANK YOU! Gps locks in seconds and stays locked instead of locking then unlocking after 2 minutes like before. Big ups!
GPS bug I encountered: being from time to time located 50m northward (upsetting when the mains highways are E-W). Working great for the moment :-)
This solution saved me! Thanks a lot.
Sir... Thank you! I was considering to buy another phone, but i love my LGG3 D855 this worked for me too.
I would hug you if i could, thank you! (Hail from Brazil!)
My GPS had been sporadic ever since Pokemon Go launched (never used it much before then). Some days weren't bad, other days I couldn't get a stable enough signal to do much of anything.
After venting my frustrations a bit on the phone, the back cover came slightly loose in one corner, and I recalled this DIY fix, tried it out, and thus far the GPS has been more stable/accurate than it EVER was.
Hopefully this fix lasts. I was beginning to compare features on new (0-dollar) phones. it was starting to give me a headache figuring out what features I could live without, and what was/wasn't an upgrade... (Probably going to need to upgrade soon anyway, as the OS isn't being updated for this model)
This will NOT do anything for cell/gps signal the connectors on the back panel are for NFC, nothing more.
kansasboy001 - Responder
NFC connector is just the one next to the camera&key opening.
Blaz - Responder
