Ir para o conteúdo principal
How to fix Bad GPS and Cell Phone Signal for LG G2
O que você precisa
Vídeo de Apresentação
  1. How to fix Bad GPS and Cell Phone Signal for LG G2, How to fix Bad GPS and Cell Phone Signal for LG G2: passo 1, imagem 1 %32
    • Tools required.
  2. How to fix Bad GPS and Cell Phone Signal for LG G2: passo 2, imagem 1 %32
    • Open the back panel and locate these three connectors.
  3. How to fix Bad GPS and Cell Phone Signal for LG G2: passo 3, imagem 1 %32
    • Gently lift up all three connectors.
  4. How to fix Bad GPS and Cell Phone Signal for LG G2: passo 4, imagem 1 %32
    • Cut a piece of thin cardboard.
  5. How to fix Bad GPS and Cell Phone Signal for LG G2: passo 5, imagem 1 %32
    • Cut the pieces close to the size of the connectors.
  6. How to fix Bad GPS and Cell Phone Signal for LG G2: passo 6, imagem 1 %32
    • Place the cardboard pieces under all three connectors.
  7. How to fix Bad GPS and Cell Phone Signal for LG G2: passo 7, imagem 1 %32
    • Gently press down the conectors.
  8. How to fix Bad GPS and Cell Phone Signal for LG G2: passo 8, imagem 1 %32
    • Close the back panel.
Conclusão
20 outras pessoas executaram este guia.
bonetti
Membro desde: 07/09/15
610 Reputação
Autoria de 1 guia
7Comentários do guia
THANK YOU THANK YOU! Gps locks in seconds and stays locked instead of locking then unlocking after 2 minutes like before. Big ups!
Garrett Wayne - Responder
Vielen Dank, GPS funktioniert bei mir wieder richtig gut. Einer der 3 Kontakte war gut verklebt. Er musste mit einem Teppichmesser unterschnitten werden, was äusserste Vorsicht erfordert.
Peter - Responder
GPS bug I encountered: being from time to time located 50m northward (upsetting when the mains highways are E-W). Working great for the moment :-)
A. Delille - Responder
This solution saved me! Thanks a lot.
ogrean florin - Responder
Sir... Thank you! I was considering to buy another phone, but i love my LGG3 D855 this worked for me too.
I would hug you if i could, thank you! (Hail from Brazil!)
leandrowsp - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 29
Ao todo: 74,424
