Ir para o conteúdo principal
How to extract a leaked battery from a pocket-torchlight
O que você precisa
  1. How to extract a  leaked battery from a pocket-torchlight, battery: passo 1, imagem 1 %32 How to extract a  leaked battery from a pocket-torchlight, battery: passo 1, imagem 2 %32
    • To successfully extract a cylindrical dry-cell (e.g. AAA , baby–cell) on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill. Drill it through the bottom of the battery to get a grip on it and retract it. Works ! Do not destroy the case by using excessive force.
Conclusão
To successfully extract a cylindrical dry-cell on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill.
Drill it through the bottom of the battery to get a grip on it and retract it. Works like a charm!
Counter the drill at the battery-case but NOT against the torch'es topside to avoid structural damage to the torchlight.
Uma outra pessoa concluiu este guia.
ein Stein
Membro desde: 12/07/20
174 Reputação
Autoria de 1 guia
7 comentários
works like a charm! there is no better way. obviously, the leaked battery is being destroyed in the process.
ein Stein - Responder
works for aluminium € 30 “creed-light”
getting the battery out is much easier than publishing a guide here. wow they make it complicated!
don’t forget to scratch off any insulating rust caused by the electrolyte on the battery–contacts of the torchlight.
fragile plastic torches may not withstand the force required to drill, breaking the torch.
unless you have a strong magnet to pull the battery, it is unfortunate.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 25
Duração total: 653
