Ir para o conteúdo principal
How to empty and clean Rival 16131 Toaster crumb tray
O que você precisa
  1. How to empty and clean Rival 16131 Toaster crumb tray, How to empty and clean Rival 16131 Toaster crumb tray: passo 1, imagem 1 %32 How to empty and clean Rival 16131 Toaster crumb tray, How to empty and clean Rival 16131 Toaster crumb tray: passo 1, imagem 2 %32
    • To open the crumb tray, pinch the lever in the photo.
    • If the lever does not keep the the crumb tray closed, stretch the lever so that to make sure the two horizontal pieces are aligned.
  2. How to empty and clean Rival 16131 Toaster crumb tray: passo 2, imagem 1 %32
    • Now that the tray is exposed, it is possible to clean the face here.
    • Try to not let water get into the toaster as this may damage the heating coil.
    • If the tray can not be cleaned simply by opening it, keep going through the guide to fully remove it.
  3. How to empty and clean Rival 16131 Toaster crumb tray: passo 3, imagem 1 %32 How to empty and clean Rival 16131 Toaster crumb tray: passo 3, imagem 2 %32 How to empty and clean Rival 16131 Toaster crumb tray: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • To remove the tray, the metal hinges must be bent up.
    • While applying pressure to the bottom of the toaster, use pliers or tweezers to bend up the bracket. The pressure applied to the bottom of the toaster should be just enough to allow the bracket to swing up.
    • Remove the tray and clean.
Conclusão
Grant Haug
Membro desde: 09/26/12
148 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 2-8, Propen Fall 2012 Membro de Cal Poly, Team 2-8, Propen Fall 2012
CPSU-PROPEN-F12S2G8
Membros da 5
Autoria de 6 guias
Um comentário
Thanks! This was helpful. :)
Tracy Emmanuel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 3,219
