Ir para o conteúdo principal
How to perform a Hard Reset on the Nintendo DS Lite
O que você precisa
  1. How to perform a Hard Reset on the Nintendo DS Lite, Battery: passo 1, imagem 1 %32
    • Turn the DS to the back side.
  2. How to perform a Hard Reset on the Nintendo DS Lite: passo 2, imagem 1 %32 How to perform a Hard Reset on the Nintendo DS Lite: passo 2, imagem 2 %32
    • This is the PH00 Screw,
    • Unscrew it.
    • The screw remains captive to the battery cover, you do not need to worry about losing it.
  3. How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: passo 3, imagem 1 %32 How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: passo 3, imagem 2 %32
    • Remove the battery cover.
  4. How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: passo 4, imagem 1 %32 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: passo 4, imagem 2 %32 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: passo 4, imagem 3 %32
    • Wedge the edge on the side of the battery using a spudger.
  5. How to perform a Hard Reset on the Nintendo DS Lite, .: passo 5, imagem 1 %32
    • Take out the battery and leave it for at least 15-30 seconds.
  6. How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: passo 6, imagem 1 %32 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: passo 6, imagem 2 %32 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: passo 6, imagem 3 %32
    • Reinsert the battery.
    • Make sure the battery matches the + and the - connectors.
  7. How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: passo 7, imagem 1 %32 How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: passo 7, imagem 2 %32
    • Put the cover back on and screw it in.
  8. How to perform a Hard Reset on the Nintendo DS Lite, Finish: passo 8, imagem 1 %32
    • If everything done correctly, You should be at the setup screen, It would look like when you got the ds from the store.
    • You can hold A + B + X + Y + R while turning on the system and the ds will boot into a ds cartridge without doing setup, you can boot the Game Pak/GBA Cartridge if you hold A + B + X + Y + L Instead.
Conclusão
3 outras pessoas executaram este guia.
Artem Ivat
Membro desde: 02/05/20
2.709 Reputação
Autoria de 12 guias
Equipe
Kid fixers Membro de Kid fixers
Community
Membros da 154
Autoria de 291 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 77
Últimos 30 dias: 366
Duração total: 9,263
