Introdução
As with any electronic device, there may be times when it is necessary to remove the Duomatik Control Module to perform maintenance, repair, or to replace the whole module.
In this guide we will be showing you how to dismount the Viessmann Duomatik Control Module 7450156.
Locate the HMI module of the Duomatik, that you want to remove.
Ferramenta utilizada neste passo:Spudger$3.99
Insert a flathead screwdriver or a Spudger into the small notch on top of the module to gently loosen it.
Uma outra pessoa concluiu este guia.
