Introdução
This guide will tell you how to prevent somebody to steel your money and/or identity when your credit or debit card expired or is replaced.
Note this can NOT be undone
  1. Take a magnet and swipe it over the magnetic strip minimum 10 times.
    • Take a magnet and swipe it over the magnetic strip minimum 10 times.
    • Take something sharp and make hole where the chip was.
    Adicionar comentário
  2. Use a pair of scissors and cut the card into thin strips.
    • Use a pair of scissors and cut the card into thin strips.
    • See the photo.
    • It is not recommended to have the strips thicker then 2mm.
    Saving and collecting the little gold emblem could make you some money in the future.
    Clifton Linne - Responder
  3. Spread Fixmas Cheer
    Get $12 off your purchase of $50 or more with code FIXMAS12
    Spread Fixmas Cheer
    • The distance you see in the blue circle is not recommended to be more then 2mm.
    • Cut the card into many small parts as seen on the photo.
    • It is recommended to have a box/tin to prevent the parts to fly anywhere.
    • Look on the floor and on the table and see if you lost some parts of the card
    • If you found some, cut them also.
    • See previous steps.
    • Take some parts in the trash at home and some other an other place, eg work, public area, etc.
    • Recomanded min 2 places
      • Taking it to the neighbor will not increase security a lot.
Linha de Chegada
24 outras pessoas concluíram este guia.
Truls Zhong Konstali
1.318 reputação
Autoria de 1 guia
You didn't mention how to destroy the chip. You need to destroy the chip also. Otherwise this method is very good (excellent if it wasn't a chip card.)
thealy449 - Responder
Would've been easier to burnt the CC to ashes . Now that's one and only one way that you will keep it from falling in to the anyone's scam, fraud...
Hiram Pabon - Responder
Please correct some typo but yes you got the
Now for anything that has 2 do w/a/pc's smartphone has a has a has a.
Rabitts take the hard drive and burnt it to a crispy ashes.
Fire destroyed anything
Destroys anything
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 28
Últimos 30 dias: 121
Todo: 9,263
