Ir para o conteúdo principal
How to clone a Hard Drive or a Solid State Drive on a Mac
O que você precisa
    1. How to clone a Hard Drive or a Solid State Drive on a Mac, Downloading Carbon Copy Cloner: passo 1, imagem 1 %32
      • Download Carbon Copy Cloner from the Bombich Software Website.
      • Install it onto your macOS based computer. You will need administrator privileges later, as well as to move CCC into the Applications folder on your computer.
      • You can download it here.
      • I used CCC 5 for this process and if the user interface changes in the future I will promptly update the guide.
      Pergunte ao FixBot
      Comentar
    2. How to clone a Hard Drive or a Solid State Drive on a Mac, Preparing for Cloning - Source Disk: passo 2, imagem 1 %32
      • Once you are at the main screen of Carbon Copy Cloner, insert your SATA based SSD/SSHD/HDD into your enclosure and plug it into your Mac.
      • Under Source Disk, click your current HD/SSD. For example, my current drive is named "Macintosh SSD".
      Pergunte ao FixBot
      Comentar
    3. How to clone a Hard Drive or a Solid State Drive on a Mac, Preparing for Cloning - Target Disk: passo 3, imagem 1 %32
      • Next, select your Target Disk. My target disk is named "Ubuntu". Your disk can have any type of name ex. "Pie".
      Pergunte ao FixBot
      Comentar
    4. How to clone a Hard Drive or a Solid State Drive on a Mac, Cloning: passo 4, imagem 1 %32
      • Lastly, click Clone.
      • Enter your administrator Username
      • Enter your administrator Password
      • Then finally, click OK
      • This process can take up to 4+ hours depending on your disk size, so have some patience!
      Pergunte ao FixBot
      Comentar
Conclusão
After you finish, install your new Hard Drive/Solid State Drive and test if it works. If it does not, try cloning again. If it still does not work after that, leave a comment and I will try my best to support you.
29 outras pessoas executaram este guia.
[deleted]
Membro desde: 08/28/18
27.956 Reputação
Autoria de 21 guias
10Comentários do guia
I have used CCC for years and years. It is an excellent program!
When upgrading MAC OS to a new version, I always clone a drive before starting the upgrade.
Mal - Responder Compartilhar
What if you have several volumes on each disk ? Does it scan the entire structure and boot options ?
Fran Werttt - Responder Compartilhar
CCC clones per volume, not per disk. So you have to clone each volume on their own, how many are bootable?
Jelan - Responder Compartilhar
I have tried cloning my 2012 Mac book pro with a vector ssd sata111, my Mac does not see the disk when I connect with usb or caddy, this is getting frustrating anyone has the same problem where you mac not seeing the ssd drive
thank you
Peter
Peter - Responder Compartilhar
What about using Restore on Disk Utility read on web that this in itself a cloning method don’t have to go for 3rd party apps
GBish - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 115
Últimos 30 dias: 433
Ao todo: 62,072
