Ir para o conteúdo principal
How to clear a Epson Stylus Photo 820 paper jam
  1. How to clear a Epson Stylus Photo 820 paper jam, How to clear a Epson Stylus Photo 820 paper jam: passo 1, imagem 1 %32 How to clear a Epson Stylus Photo 820 paper jam, How to clear a Epson Stylus Photo 820 paper jam: passo 1, imagem 2 %32
    • If a paper jam is detected, the middle button will display a red light.
    • Press the red button. This will cause the printer to try to automatically correct the issue.
    • If this works, proceed to step 4. Otherwise, proceed to step 2.
  2. How to clear a Epson Stylus Photo 820 paper jam: passo 2, imagem 1 %32 How to clear a Epson Stylus Photo 820 paper jam: passo 2, imagem 2 %32
    • The first step in repair is to attempt to remove the paper jam by pulling it out through the top.
    • Pull the paper slowly, and as straight as possible.
    • If this does not work, proceed to step 3.
  3. How to clear a Epson Stylus Photo 820 paper jam: passo 3, imagem 1 %32 How to clear a Epson Stylus Photo 820 paper jam: passo 3, imagem 2 %32
    • Assuming the paper will not come out of the top, assess the paper jam.
    • If the print cartridge is in the way, gently push it to the side.
    • Try to get the full edge of the paper above the metal grating.
    • Gently pull the paper out the of the open hatch.
  4. How to clear a Epson Stylus Photo 820 paper jam: passo 4, imagem 1 %32 How to clear a Epson Stylus Photo 820 paper jam: passo 4, imagem 2 %32
    • If the paper jam was corrected during step 1, the red light should have turned off, leaving only a green light.
    • If steps 2 or 3 corrected the problem, you will need to press the red button again.
    • This may cause another sheet of paper to be pulled through. Do not be alarmed.
    • This should cause the red light to go out.
Linha de Chegada
Uma outra pessoa concluiu este guia.
dante gagliardi
Membro desde: 04/13/11
45 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-68, Walters Spring 2011 Membro de Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 3,247
