Ir para o conteúdo principal
How to clear Lexmark Intuition S505 paper jam
  1. How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: passo 1, imagem 1 %32 How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: passo 1, imagem 2 %32
    • Lift the scanning unit.
  2. How to clear Lexmark Intuition S505 paper jam: passo 2, imagem 1 %32 How to clear Lexmark Intuition S505 paper jam: passo 2, imagem 2 %32
    • Check the duplex unit, located at the rear of the printer, for any paper obstruction. Pinch the top button to remove the unit.
  3. How to clear Lexmark Intuition S505 paper jam: passo 3, imagem 1 %32
    • If there is any paper stuck inside, remove it. If not, snap the unit back onto the printer.
  4. How to clear Lexmark Intuition S505 paper jam: passo 4, imagem 1 %32
    • Check the front slot, which is located underneath the LED display. If there is any paper, remove it.
Conclusão
Once the paper obstruction is removed, your printer should print smoothly without any problems.
Omar
Membro desde: 01/23/13
111 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-38, Regan Winter 2013 Membro de Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
Membros da 4
Autoria de 8 guias
Um comentário
Mine still says paper jam but there's no paper stuck in it all. Can you suggest other probs and solutions?
Debra Collis (Debbie) - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 1,654
