Ir para o conteúdo principal
How to clean/replace buttons on the Skytex SP728
O que você precisa
  1. How to clean/replace buttons on the Skytex SP728, Case: passo 1, imagem 1 %32
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. How to clean/replace buttons on the Skytex SP728: passo 2, imagem 1 %32
    • Using a small phillips screwdriver, unscrew both end screws
  3. How to clean/replace buttons on the Skytex SP728: passo 3, imagem 1 %32
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. How to clean/replace buttons on the Skytex SP728: passo 4, imagem 1 %32
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. How to clean/replace buttons on the Skytex SP728, How to clean/replace buttons on the Skytex SP728: passo 5, imagem 1 %32
    • Remove the black buttons (they should not be directly attached to the device and may fall out).
  6. How to clean/replace buttons on the Skytex SP728: passo 6, imagem 1 %32
    • On side the circuit board there will be three buttons. One is the power button, and the other two are volume buttons.
Conclusão
Uma outra pessoa concluiu este guia.
Chris Nelson
Membro desde: 01/21/15
213 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-1, Brown Winter 2015 Membro de USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 121
