Ir para o conteúdo principal
How to clean your Roomba 4100's air filter.
O que você precisa
  1. How to clean your Roomba 4100's air filter., How to clean your Roomba 4100's air filter.: passo 1, imagem 1 %32
    • Slide out back bin by pressing the unmarked button on top of the Roomba.
  2. How to clean your Roomba 4100's air filter.: passo 2, imagem 1 %32
    • Slide out yellow bar on particle bin to access filter
  3. How to clean your Roomba 4100's air filter.: passo 3, imagem 1 %32
    • This is the air filter assembly
  4. How to clean your Roomba 4100's air filter.: passo 4, imagem 1 %32
    • Pop out filter mount by prying 2 points that hold it to the rest of the assembly
  5. How to clean your Roomba 4100's air filter.: passo 5, imagem 1 %32
    • Thoroughly clean or replace the air filter. This can be done with compressed air or by rinsing it with water.
  6. How to clean your Roomba 4100's air filter.: passo 6, imagem 1 %32
    • Reassemble the air filter assembly and slide the particle bin back into place
Conclusão
3 outras pessoas executaram este guia.
Scott Leonard
Membro desde: 10/05/10
445 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-6, Maness Fall 2010 Membro de Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
Membros da 2
Autoria de 3 guias
Um comentário
Good thing to know this, I can clean my own Air purifier at home my myself. Anyway this is what my air filter like http://ariixproducts.com/puritii-water-a...
top.ariixproducts - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 5,211
