Introdução
This guide will walk you through the steps to cleaning the Roomba air filter. A clean filter will improve performance and should be checked regularly.
Peças
Não são necessárias peças.
  1. Slide out back bin by pressing the unmarked button on top of the Roomba.
    • Slide out back bin by pressing the unmarked button on top of the Roomba.
  2. Slide out yellow bar on particle bin to access filter
    • Slide out yellow bar on particle bin to access filter
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. This is the air filter assembly
    • This is the air filter assembly
  5. Pop out filter mount by prying 2 points that hold it to the rest of the assembly
    • Pop out filter mount by prying 2 points that hold it to the rest of the assembly
  6. Thoroughly clean or replace the air filter.  This can be done with compressed air or by rinsing it with water.
    • Thoroughly clean or replace the air filter. This can be done with compressed air or by rinsing it with water.
  7. Reassemble the air filter assembly and slide the particle bin back into place
    • Reassemble the air filter assembly and slide the particle bin back into place
Conclusão
3 outras pessoas concluíram este guia.
Scott Leonard
439 reputação
3 Guides authored
Equipe
Cal Poly, Team 20-6, Maness Fall 2010 Membro de Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
2 Membros
3 Guides authored
Good thing to know this, I can clean my own Air purifier at home my myself. Anyway this is what my air filter like http://ariixproducts.com/puritii-water-a...
top.ariixproducts - Responder
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Todo: 4,712
