Ir para o conteúdo principal
How to clean your Panasonic SA-HT810V VCR heads
O que você precisa
  1. How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: passo 1, imagem 1 %32 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: passo 1, imagem 2 %32 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: passo 1, imagem 3 %32
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. How to clean your Panasonic SA-HT810V VCR heads: passo 2, imagem 1 %32 How to clean your Panasonic SA-HT810V VCR heads: passo 2, imagem 2 %32
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the 12 screws highlighted by the red circles in image one.
  3. How to clean your Panasonic SA-HT810V VCR heads: passo 3, imagem 1 %32
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. How to clean your Panasonic SA-HT810V VCR heads: passo 4, imagem 1 %32 How to clean your Panasonic SA-HT810V VCR heads: passo 4, imagem 2 %32 How to clean your Panasonic SA-HT810V VCR heads: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Before cleaning the VCR heads, be sure that the front of the device is facing you with the top cover removed.
    • Locate the two VCR heads highlighted in by the blue boxes in image one.
    • GENTLY clean heads with a microfiber rag and a cleaning solution of your choice.
Conclusão
Nathan Cheadle
Membro desde: 04/15/10
161 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 16-5, Maness Spring 2010 Membro de Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 2,668
