Ir para o conteúdo principal
How to clean the Sega Genesis game port
O que você precisa
  1. How to clean the Sega Genesis game port, How to clean the Sega Genesis game port: passo 1, imagem 1 %32
    • Fold fine grit sand paper over a credit card.
  2. How to clean the Sega Genesis game port: passo 2, imagem 1 %32
    • Rub credit card with sand paper up and down vertically inside the game cartridge port.
  3. How to clean the Sega Genesis game port: passo 3, imagem 1 %32
    • Blow out game cartridge port using a can of compressed air.
    • Warning: Do not turn the aerosol can upside down as you spray.
  4. How to clean the Sega Genesis game port: passo 4, imagem 1 %32
    • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
Linha de Chegada
11 outras pessoas executaram este guia.
Erik Bjornstrom
Membro desde: 10/04/10
829 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 3-29, Regan Fall 2010 Membro de Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
Membros da 4
Autoria de 14 guias
4 comentários
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - Responder
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - Responder
I have a sega genesis 1 the only thing i cant get to work are the conteollers all of them arent connecting i checked the pins and they all look fine. I really want this to work so i can play zombie ate my neighbors
laslidco - Responder
Worked great for my Sega Genesis Model 2 console (which was super flaky before). Also cleaned my cartridge contacts with rubbing alcohol on cotton swabs, made a HUGE difference. Thank you for this.
fcjohnson65 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 33
Últimos 30 dias: 156
Duração total: 36,039
