Ir para o conteúdo principal
How to clean the Samsung SGH-E317 keypad
O que você precisa
  1. How to clean the Samsung SGH-E317 keypad, Battery: passo 1, imagem 1 %32
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. How to clean the Samsung SGH-E317 keypad, Motherboard: passo 2, imagem 1 %32
    • Unscrew the four 4.5mm screws located on the back plate.
  3. How to clean the Samsung SGH-E317 keypad: passo 3, imagem 1 %32
    • Remove the rubber screw cover using your fingernail.
  4. How to clean the Samsung SGH-E317 keypad: passo 4, imagem 1 %32
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. How to clean the Samsung SGH-E317 keypad: passo 5, imagem 1 %32
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. How to clean the Samsung SGH-E317 keypad: passo 6, imagem 1 %32
    • With the back panel removed, the motherboard should be fully exposed.
  7. How to clean the Samsung SGH-E317 keypad: passo 7, imagem 1 %32 How to clean the Samsung SGH-E317 keypad: passo 7, imagem 2 %32
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. How to clean the Samsung SGH-E317 keypad: passo 8, imagem 1 %32 How to clean the Samsung SGH-E317 keypad: passo 8, imagem 2 %32
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. How to clean the Samsung SGH-E317 keypad: passo 9, imagem 1 %32 How to clean the Samsung SGH-E317 keypad: passo 9, imagem 2 %32
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
  10. How to clean the Samsung SGH-E317 keypad, How to clean the Samsung SGH-E317 keypad: passo 10, imagem 1 %32
    • After removing motherboard, the phone will look like this.
  11. How to clean the Samsung SGH-E317 keypad: passo 11, imagem 1 %32
    • Grab the corner of the rubber key pad and lift out slowly.
  12. How to clean the Samsung SGH-E317 keypad: passo 12, imagem 1 %32 How to clean the Samsung SGH-E317 keypad: passo 12, imagem 2 %32
    • By using a small standard screwdriver and a fine, thin, soft cloth you can clean in between the keypad to remove dirt and debris.
Conclusão
Uma outra pessoa concluiu este guia.
Joe Cavaletto
Membro desde: 01/30/11
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 11-23, Maness Winter 2011 Membro de Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 1,086
