Ir para o conteúdo principal
How to clean the Pentax PZ-10 gears
O que você precisa
  1. How to clean the Pentax PZ-10 gears, Removing the Bottom Cover Screws: passo 1, imagem 1 %32 How to clean the Pentax PZ-10 gears, Removing the Bottom Cover Screws: passo 1, imagem 2 %32
    • Place the lens face up to locate the bottom cover.
    • Remove the two 7mm screws using a J0 screwdriver.
    • Remove the six 4.3 mm screws using a J0 screwdriver.
  2. How to clean the Pentax PZ-10 gears, Removing the Bottom Cover: passo 2, imagem 1 %32
    • After the screws are removed, the bottom cover should easily pry off.
  3. How to clean the Pentax PZ-10 gears, Accessing Gears: passo 3, imagem 1 %32 How to clean the Pentax PZ-10 gears, Accessing Gears: passo 3, imagem 2 %32
    • Using a J0 screwdriver, remove the 4mm screw holding the metal plate to expose the gears.
  4. How to clean the Pentax PZ-10 gears, Removing Gear Housing Plate: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, gently remove the metal plate covering the gears.
    • Part of the plate's tab fits into a socket. Try to pivot around it when removing the plate to prevent bending the plate.
    • Be careful with the gears because some may be loose.
  5. How to clean the Pentax PZ-10 gears, Cleaning the Gears: passo 5, imagem 1 %32 How to clean the Pentax PZ-10 gears, Cleaning the Gears: passo 5, imagem 2 %32
    • Use tweezers to rotate gears or remove any large particles obstructing their rotation.
    • Smaller particles can be cleared using a microfiber cloth only. Other fabrics may leave residual fibers.
Conclusão
Uma outra pessoa concluiu este guia.
Bryan Sugiarto
Membro desde: 04/20/15
252 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 994
