Ir para o conteúdo principal
How to clean the Olympus Stylus 760 lens and sensor
O que você precisa
  1. How to clean the Olympus Stylus 760 lens and sensor, How to clean the Olympus Stylus 760 lens and sensor: passo 1, imagem 1 %32
  2. How to clean the Olympus Stylus 760 lens and sensor: passo 2, imagem 1 %32
    • Remove the screw located on the right side of the camera
  3. How to clean the Olympus Stylus 760 lens and sensor: passo 3, imagem 1 %32
    • Remove the two screws from the left side of the camera
  4. How to clean the Olympus Stylus 760 lens and sensor, Separation: passo 4, imagem 1 %32
    • Use a small prying device to delicately separate the front casing from the back.
New line.
    • When separating the 2 cases be cautious of the silver band and buttons that located in the middle of the camera. They will come loose.
  5. How to clean the Olympus Stylus 760 lens and sensor: passo 5, imagem 1 %32 How to clean the Olympus Stylus 760 lens and sensor: passo 5, imagem 2 %32 How to clean the Olympus Stylus 760 lens and sensor: passo 5, imagem 3 %32
    • Remove the 2 screws on the right side of the camera.
    • Remove the 2 screwson the left side of the camera
    • CAUTION! Circuit ribbon is attached at the top left of the camera be careful when separating the front and back of the camera after removing the 4 screws.
  6. How to clean the Olympus Stylus 760 lens and sensor: passo 6, imagem 1 %32
    • Carefully flip up the clip attaching the ribbon from the rear to the front and pull it out
  7. How to clean the Olympus Stylus 760 lens and sensor: passo 7, imagem 1 %32
    • Carefully separate the front and back of the camera
  8. How to clean the Olympus Stylus 760 lens and sensor: passo 8, imagem 1 %32
    • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  9. How to clean the Olympus Stylus 760 lens and sensor: passo 9, imagem 1 %32
    • Using a size 0 Phillips head, remove 3 screws holding the ribbon cable that covers the back of the lens.
    • CAUTION: small loose pieces under the back lens cover
  10. How to clean the Olympus Stylus 760 lens and sensor: passo 10, imagem 1 %32
    • Using tweezers remove tiny square lens cases. There are 4 small pieces.
    • The pieces are relatively small, so becareful that they do not fall inside of the lens.
  11. How to clean the Olympus Stylus 760 lens and sensor: passo 11, imagem 1 %32
    • Remove the larger black rubber frame. Clean with condensed air.
Conclusão
Derek Guzman
Membro desde: 02/10/12
17 Reputação
Autoria de 1 guia
Equipe
James Madison, Team 3-3, Klein Spring 2012 Membro de James Madison, Team 3-3, Klein Spring 2012
JMU-KLEIN-S12S3G3
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 1,932
