Ir para o conteúdo principal
How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers
O que você precisa
  1. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Back Panel: passo 1, imagem 1 %32
    • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  2. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Inner Back Pannel: passo 2, imagem 1 %32 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Inner Back Pannel: passo 2, imagem 2 %32
    • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  3. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Upper Portion: passo 3, imagem 1 %32 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Upper Portion: passo 3, imagem 2 %32
    • Press down on the two plastic hinges to remove the upper portion of printer.
    The two plastic hinges WON’T PRESS DOWN in order to release them from their housing and lift away the top. I am even resorting to wedging a very thin flat headed screwdriver in on top of the hinge to see if this makes a difference but nothing will budge.
    Maeshowie - Responder
    Further to my first comment, the hinge in the diagram looks slightly different to the ones on the rear of my printer in that the diagram ones look as if they WILL press down, finger force, to release the top.
    I’ve given up and am putting it all back together again. Must now look to see if I can send this printer to someone who knows what they are doing.
    Third and last comment. I tried one last time to release the top, pressed down on the hinge - and it snapped off. This one to the dump and online to buy a new one.
  4. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Unplug Speaker Wire: passo 4, imagem 1 %32
    • Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
  5. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray: passo 5, imagem 1 %32 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray: passo 5, imagem 2 %32
    • Rotate the printer so the paper tray is facing towards you.
    • Gently lift the scanner tray up and away from the printer.
    • Press the gray plastic tabs inward to release the tabs from the printer.
  6. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray - cont.: passo 6, imagem 1 %32
    • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
    It would be easer to do steps 7 & 8 before step 6.
    Richard Scott - Responder
  7. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: passo 7, imagem 1 %32
    • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
  8. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: passo 8, imagem 1 %32
    • Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
  9. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Detaching the Scanner Tray: passo 9, imagem 1 %32
    • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
    But how do you get to the inside of scaner?
    R S V P Urgent
    Paul D
    pauldaley08 - Responder
    As from N0 9 Done thus far but can not get inside scanner itself. Have removed screw Back L H Side, but do not wish to brake in — somthing is holding (more screws?)
    Yrs Paul D
    pauldaley08@hotmail.com
  10. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: passo 10, imagem 1 %32
    • Using the T10 Torx Security Bit Screwdriver, remove the four black screws holding the printer carriage cover in place.
  11. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: passo 11, imagem 1 %32
    • Depress plastic tabs to release the cover from the sides.
    • There is nothing holding the left side panel in place, so pull it away from the printer body.
  12. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: passo 12, imagem 1 %32
    • Turn the smallest white plastic gear on the left side of the printer to rotate feed rollers.
  13. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Clean Rollers: passo 13, imagem 1 %32
    • While rotating the feed rollers, clean them with purified or distilled water and a lint-free cloth.
Conclusão
3 outras pessoas executaram este guia.
Cody Long
Membro desde: 04/12/11
153 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-31, Maness Spring 2011 Membro de Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
Membros da 5
Autoria de 9 guias
Um comentário
Nice instructions, but there's nothing here about the video card readers on the right front. Can't get the right-side panel off. Otherwise, the instructions are well displayed.
Gayle Bryan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 11,991
