Ir para o conteúdo principal
How to clean the Avanti 308YWT evaporator pan
  1. How to clean the Avanti 308YWT evaporator pan, How to clean the Avanti 308YWT evaporator pan: passo 1, imagem 1 %32
    • Before starting, unplug the refrigerator.
  2. How to clean the Avanti 308YWT evaporator pan: passo 2, imagem 1 %32
    • Go to the bottom of the back side of the refrigerator and locate the cut out where the compressor and evaporator are stored.
  3. How to clean the Avanti 308YWT evaporator pan: passo 3, imagem 1 %32
    • Remove the evaporator tray by simply pulling up and out the tray. make sure that none of the liquid spills.
  4. How to clean the Avanti 308YWT evaporator pan: passo 4, imagem 1 %32 How to clean the Avanti 308YWT evaporator pan: passo 4, imagem 2 %32
    • The evaporator tray might have ice build up on it. You can remove this ice by pouring warm water on the tray. After the ice is melted, clean the tray with warm water and soap.
  5. How to clean the Avanti 308YWT evaporator pan: passo 5, imagem 1 %32
    • Dry and reinsert the tray.
  6. How to clean the Avanti 308YWT evaporator pan: passo 6, imagem 1 %32
    • Plug the refrigerator back in.
Conclusão
7 outras pessoas executaram este guia.
Seye
Membro desde: 10/11/14
371 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-38, Donnelly Fall 2014 Membro de USF Tampa, Team 1-38, Donnelly Fall 2014
USFT-DONNELLY-F14S1G38
1 Membro
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 38
Duração total: 3,502
