Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
Remove the metal vent piece that is below the door.
Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
Remove the crumb tray (the bottom, metal panel) from the toaster unit.
Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
Remove the knobs by pulling them upward; they should slide right off.
When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
Unhook the bottom of the the display panel from the toaster unit.
Begin to detach the back panel from the toaster unit.
Then, unhook the rest of the display panel.
Finish removing the outside cover by lifting the lid upward.
Remove the four Phillips #4 1 cm screws from the back of the unit.
Now, you can clean the outside units of the toaster oven.
Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
4 outras pessoas executaram este guia.
Um comentário
This guide is amazing - almost equally because it is so detailed and thorough as because it helped me know exactly how to clean this almost ancient piece of equipment, that's still going strong after what must be 40+ years (in spite of not having been thoroughly, properly cleaned in probably 20!) Acknowledgement to Black & Decker of that era too - let's hear it for American-made products like this one! Thank you for creating this guide!
