Ir para o conteúdo principal
How to Clean the Dell MO56UC
O que você precisa
  1. How to Clean the Dell MO56UC, Disassembly: passo 1, imagem 1 %32 How to Clean the Dell MO56UC, Disassembly: passo 1, imagem 2 %32
    • Unplug the USB cord to disconnect the mouse from the power
    • Use a Phillips 00 Screwdriver to unscrew one screw.
  2. How to Clean the Dell MO56UC, Complete mouse disassembly: passo 2, imagem 1 %32
    • Take off the top of the mouse.
    • Use a microfiber cloth or a damp towel to remove any debris located inside of the highlighted areas.
  3. How to Clean the Dell MO56UC, Sensors: passo 3, imagem 1 %32
    • Twist the ball counter-clockwise to remove it.
    • Clean the ball with a microfiber cloth.
  4. How to Clean the Dell MO56UC, Wipe gently with microfiber cloth: passo 4, imagem 1 %32
    • Clean the vertical and horizontal ball sensors with a microfiber cloth.
  5. How to Clean the Dell MO56UC, Examining Wheel: passo 5, imagem 1 %32
    • Examine the wheel for debris. The wheel can get dirty frequently which affects performance and may cause issues.
    • Remove any debris found and clean the wheel with a microfiber cloth.
  6. How to Clean the Dell MO56UC, Sensor Error: passo 6, imagem 1 %32
    • The wheel clicker sensor is located under the wheel.
  7. How to Clean the Dell MO56UC, Wheel Clicker: passo 7, imagem 1 %32
    • Remove the wheel to expose the sensor.
    • Remove any debris and wipe down the sensor with a microfiber cloth.
  8. How to Clean the Dell MO56UC, Plug it back in: passo 8, imagem 1 %32
    • Insert the USB Cable back into your computer to supply with power.
    • Test functions of the mouse to insure proper cleaning and reassembly.
  9. How to Clean the Dell MO56UC, If there are still issues, Examine the cord and the USB leads in the male port: passo 9, imagem 1 %32
    • Examine the cord for frays or any exposed wire that may cause a bad connection.
Conclusão
4 outras pessoas executaram este guia.
Equipe
Montana Tech, Team 1-4, Shirk Fall 2014 Membro de Montana Tech, Team 1-4, Shirk Fall 2014
MTUM-SHIRK-F14S1G4
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 62
Duração total: 3,403
