Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Like all graphics cards, the Radeon X1900 XTX occasionally needs to be opened up and cleaned in order to function properlly.
Once you remove the heat sink, you'll need to reapply thermal paste to the GPU die. Follow our Applying Thermal Paste Guide for detailed directions.
O que você precisa
Start by removing the card from the PC if you haven't already.
Re-Applying Thermal Paste:
Apply a small glob of thermal paste to the corner of the die, (I recommend using Arctic Silver 5) and use an index card to spread a thin, even layer of it over the surface of the chip.
For more detailed directions, follow our Applying Thermal Paste Guide.
13 outras pessoas executaram este guia.
