Ir para o conteúdo principal
How to clean and maintain your Vape Mod
O que você precisa
  1. How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: passo 1, imagem 1 %32 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: passo 1, imagem 2 %32 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: passo 1, imagem 3 %32
    • Although maintenance for your Vape Mod shouldn't be dangerous, it can be messy. It is recommended to do this on top of a paper towel.
    • Start by removing the top cap of your Vape Mod.
  2. How to clean and maintain your Vape Mod: passo 2, imagem 1 %32 How to clean and maintain your Vape Mod: passo 2, imagem 2 %32 How to clean and maintain your Vape Mod: passo 2, imagem 3 %32
    • Unscrew RDA (rebuildable dripping atomizer) and take it off.
  3. How to clean and maintain your Vape Mod: passo 3, imagem 1 %32 How to clean and maintain your Vape Mod: passo 3, imagem 2 %32 How to clean and maintain your Vape Mod: passo 3, imagem 3 %32
    • Many Vape Mods are different, you might have to take out your battery in a different way than shown.
    • At the bottom of the tube, unscrew the firing pin.
    • Take the battery out of the Vape Mod.
  4. How to clean and maintain your Vape Mod: passo 4, imagem 1 %32 How to clean and maintain your Vape Mod: passo 4, imagem 2 %32 How to clean and maintain your Vape Mod: passo 4, imagem 3 %32
    • Inspect all of the parts that will need to be cleaned:
    • The firing pin
    • The RDA threading
    • The bottom of the inside of the tube
  5. How to clean and maintain your Vape Mod: passo 5, imagem 1 %32 How to clean and maintain your Vape Mod: passo 5, imagem 2 %32
    • Clean the Firing pin by dipping a paper towel into hot water.
    • Carefully rotate the hot towel around the middle area, rubbing the grime away.
  6. How to clean and maintain your Vape Mod: passo 6, imagem 1 %32 How to clean and maintain your Vape Mod: passo 6, imagem 2 %32 How to clean and maintain your Vape Mod: passo 6, imagem 3 %32
    • Get a new paper towel wet with the hot water.
    • Clean the RDA threading by rotating the wet paper towel back and forth across it.
  7. How to clean and maintain your Vape Mod: passo 7, imagem 1 %32 How to clean and maintain your Vape Mod: passo 7, imagem 2 %32 How to clean and maintain your Vape Mod: passo 7, imagem 3 %32
    • Twist it until it can easily fit inside of the tube.
    • Use your finger or another long tool to rotate the paper towel along the sides and the bottom of the tube.
  8. How to clean and maintain your Vape Mod: passo 8, imagem 1 %32 How to clean and maintain your Vape Mod: passo 8, imagem 2 %32 How to clean and maintain your Vape Mod: passo 8, imagem 3 %32
    • Put your Vape Mod back together by doing steps 1 - 2 in reverse. (Leave the mouthpiece of the top cap off).
    • Careful, firing your Vape Mod produces heat and can make the device HOT!
    • Fire your Vape Mod. If the coils are heating up, it has been fixed!
Conclusão
If your Vape Mod is still not firing, consider getting a new build.
13 outras pessoas executaram este guia.
Jessie Smith
Membro desde: 09/29/15
677 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-3, Green Fall 2015 Membro de Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 33
Duração total: 10,711
