Ir para o conteúdo principal
How to clean Sony Ericsson QuickShare T630 joystick
O que você precisa
  1. How to clean Sony Ericsson QuickShare T630 joystick, Sony Ericsson QuickShare T630 Phone Enclosure: passo 1, imagem 1 %32
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. How to clean Sony Ericsson QuickShare T630 joystick: passo 2, imagem 1 %32 How to clean Sony Ericsson QuickShare T630 joystick: passo 2, imagem 2 %32
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. How to clean Sony Ericsson QuickShare T630 joystick: passo 3, imagem 1 %32
    • Slide the battery upward to remove.
  4. How to clean Sony Ericsson QuickShare T630 joystick: passo 4, imagem 1 %32 How to clean Sony Ericsson QuickShare T630 joystick: passo 4, imagem 2 %32
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. How to clean Sony Ericsson QuickShare T630 joystick: passo 5, imagem 1 %32 How to clean Sony Ericsson QuickShare T630 joystick: passo 5, imagem 2 %32
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. How to clean Sony Ericsson QuickShare T630 joystick: passo 6, imagem 1 %32
    • Slide the aerial upward to remove it.
  7. How to clean Sony Ericsson QuickShare T630 joystick: passo 7, imagem 1 %32 How to clean Sony Ericsson QuickShare T630 joystick: passo 7, imagem 2 %32
    • Remove the four screws located at each corner of the device.
  8. How to clean Sony Ericsson QuickShare T630 joystick: passo 8, imagem 1 %32 How to clean Sony Ericsson QuickShare T630 joystick: passo 8, imagem 2 %32
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. How to clean Sony Ericsson QuickShare T630 joystick: passo 9, imagem 1 %32 How to clean Sony Ericsson QuickShare T630 joystick: passo 9, imagem 2 %32 How to clean Sony Ericsson QuickShare T630 joystick: passo 9, imagem 3 %32
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. How to clean Sony Ericsson QuickShare T630 joystick: passo 10, imagem 1 %32 How to clean Sony Ericsson QuickShare T630 joystick: passo 10, imagem 2 %32 How to clean Sony Ericsson QuickShare T630 joystick: passo 10, imagem 3 %32
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
  11. How to clean Sony Ericsson QuickShare T630 joystick, How to clean Sony Ericsson QuickShare T630 joystick: passo 11, imagem 1 %32
    • Gently lift the white circuit board to reveal the base.
  12. How to clean Sony Ericsson QuickShare T630 joystick: passo 12, imagem 1 %32
    • Soak cotton swab in rubbing alcohol
    • Gently work the cotton swab around the joystick, removing any waste buildup that may hinder its use.
Conclusão
Shelby Hartin
Membro desde: 10/28/13
143 Reputação
Autoria de 1 guia
Equipe
University of Maine, Team 1-1, Diaz Fall 2013 Membro de University of Maine, Team 1-1, Diaz Fall 2013
UMAINE-DIAZ-F13S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,135
