Ir para o conteúdo principal
How to clean Sony CCD-TR81 viewfinder
O que você precisa
  1. How to clean Sony CCD-TR81 viewfinder, Disassembling Sony CCD-TR81 Battery: passo 1, imagem 1 %32
    • Lift viewfinder to access battery pack.
  2. How to clean Sony CCD-TR81 viewfinder: passo 2, imagem 1 %32 How to clean Sony CCD-TR81 viewfinder: passo 2, imagem 2 %32
    • Press the battery release button.
    • While pushing the battery button, slide the battery to the left.
  3. How to clean Sony CCD-TR81 viewfinder: passo 3, imagem 1 %32
    • Pull the battery pack out of the video camera.
  4. How to clean Sony CCD-TR81 viewfinder, How to clean Sony CCD-TR81 viewfinder: passo 4, imagem 1 %32
    • Pull the viewfinder eyepiece out and away from the main video camera until the black mark appears.
  5. How to clean Sony CCD-TR81 viewfinder: passo 5, imagem 1 %32
    • Twist the eyepiece counterclockwise until it stops.
  6. How to clean Sony CCD-TR81 viewfinder: passo 6, imagem 1 %32
    • Pull the eyepiece completely off away from the rest of the viewfinder.
  7. How to clean Sony CCD-TR81 viewfinder: passo 7, imagem 1 %32 How to clean Sony CCD-TR81 viewfinder: passo 7, imagem 2 %32
    • Using the Small Plastic Opening tool, pry the tab on the plastic lens away from the viewfinder.
  8. How to clean Sony CCD-TR81 viewfinder: passo 8, imagem 1 %32
    • Use a cleaning cloth to wipe away residue from the viewfinder.
Conclusão
Kevin
Membro desde: 01/24/11
252 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 11-25, Maness Winter 2011 Membro de Cal Poly, Team 11-25, Maness Winter 2011
CPSU-MANESS-W11S11G25
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 25
Ao todo: 4,005
