Ir para o conteúdo principal
How to clean Samsung SGH-T639 keypad
O que você precisa
  1. How to clean Samsung SGH-T639 keypad, Battery: passo 1, imagem 1 %32
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. How to clean Samsung SGH-T639 keypad: passo 2, imagem 1 %32
    • Use button to remove battery from the phone.
  3. How to clean Samsung SGH-T639 keypad, Motherboard: passo 3, imagem 1 %32 How to clean Samsung SGH-T639 keypad, Motherboard: passo 3, imagem 2 %32 How to clean Samsung SGH-T639 keypad, Motherboard: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Locate the six (4mm) screws on the back casing of the phone.
    • Unscrew each one using a phillips head #000 screwdriver.
    • Place screws on magnetic mat.
  4. How to clean Samsung SGH-T639 keypad: passo 4, imagem 1 %32 How to clean Samsung SGH-T639 keypad: passo 4, imagem 2 %32 How to clean Samsung SGH-T639 keypad: passo 4, imagem 3 %32
    • Starting at the top of the phone, carefully insert plastic opening device into the seam.
    • Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
    • Note: Some force must be exerted. Be careful when taking off panel. Go slow.
    • Note: The volume button may separate from the case, this is normal. It is not broken.
  5. How to clean Samsung SGH-T639 keypad: passo 5, imagem 1 %32 How to clean Samsung SGH-T639 keypad: passo 5, imagem 2 %32 How to clean Samsung SGH-T639 keypad: passo 5, imagem 3 %32
    • Locate the connection point of black wire running from the microphone to the motherboard.
    • Carefully disconnect the gold connector from the motherboard using tweezers.
  6. How to clean Samsung SGH-T639 keypad: passo 6, imagem 1 %32 How to clean Samsung SGH-T639 keypad: passo 6, imagem 2 %32 How to clean Samsung SGH-T639 keypad: passo 6, imagem 3 %32
    • Locate the red connector at the top of the motherboard.
    • Carefully lift and remove the connector from the motherboard using tweezers.
  7. How to clean Samsung SGH-T639 keypad: passo 7, imagem 1 %32 How to clean Samsung SGH-T639 keypad: passo 7, imagem 2 %32 How to clean Samsung SGH-T639 keypad: passo 7, imagem 3 %32
    • Locate the gold connector that connects the screen to the motherboard.
    • Carefully disconnect the connector from the motherboard using tweezers.
  8. How to clean Samsung SGH-T639 keypad: passo 8, imagem 1 %32 How to clean Samsung SGH-T639 keypad: passo 8, imagem 2 %32 How to clean Samsung SGH-T639 keypad: passo 8, imagem 3 %32
    • Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool.
    • Lift the motherboard from the cell phone.
  9. How to clean Samsung SGH-T639 keypad: passo 9, imagem 1 %32
    • Remove the motherboard from the cell phone.
  10. How to clean Samsung SGH-T639 keypad, Keypad: passo 10, imagem 1 %32 How to clean Samsung SGH-T639 keypad, Keypad: passo 10, imagem 2 %32
    • Locate the two black, rubber tabs near the top of the back of the phone.
    • Locate the one black, rubber tab near the base of the phone.
  11. How to clean Samsung SGH-T639 keypad: passo 11, imagem 1 %32 How to clean Samsung SGH-T639 keypad: passo 11, imagem 2 %32 How to clean Samsung SGH-T639 keypad: passo 11, imagem 3 %32
    • Using tweezers, pry each of the tabs open.
    • Tuck each tab behind the white notch.
    • By tucking the tabs behind each notch. This allows improves the ease of removing the keypad.
  12. How to clean Samsung SGH-T639 keypad: passo 12, imagem 1 %32 How to clean Samsung SGH-T639 keypad: passo 12, imagem 2 %32 How to clean Samsung SGH-T639 keypad: passo 12, imagem 3 %32
    • Flip phone over to make the keypad visable.
    • Carefully lift keypad around the edges.
    • Remove keypad from the cell phone.
  13. How to clean Samsung SGH-T639 keypad, How to clean Samsung SGH-T639 keypad: passo 13, imagem 1 %32
    • Obtain device cleaner and a cleaning pad.
  14. How to clean Samsung SGH-T639 keypad: passo 14, imagem 1 %32 How to clean Samsung SGH-T639 keypad: passo 14, imagem 2 %32 How to clean Samsung SGH-T639 keypad: passo 14, imagem 3 %32
    • Spray the front of the keypad with device cleaner.
    • Clean front of keypad using cleaning cloth.
  15. How to clean Samsung SGH-T639 keypad: passo 15, imagem 1 %32 How to clean Samsung SGH-T639 keypad: passo 15, imagem 2 %32 How to clean Samsung SGH-T639 keypad: passo 15, imagem 3 %32
    • Flip keypad over.
    • Spray back of keypad with device cleaner.
    • Clean back of keypad with cleaning cloth.
Conclusão
Yi Ren
Membro desde: 03/26/14
801 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 1-4, Benson Spring 2014 Membro de Clemson, Team 1-4, Benson Spring 2014
CLEM-BENSON-S14S1G4
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 207
